Power Consumption:
On top of our graphics performance testing, we have also measured the power consumption of Inno3D's GeForce 8600 GTS iChiLL Xstriker3 graphics card at both idle and load. For this we used our standard test system configuration listed earlier on in the review.
For our idle testing, we left the systems idling on the desktop for ten minutes, recording the average draw at the wall socket. For load testing, we used our benchmark routine from
The Elder Scrolls IV: Oblivion and measured the peak power consumption in this section of the title. We tested the cards in a number of other scenarios and this proved to be the most intensive in all cases, so you can consider this to be a worst-case scenario.
Bear in mind that we have disabled all CPU-related power management options in the motherboard's BIOS so that we can highlight exactly how well the GPU's power management features are working (or not).
Asus EN8600GT 256MB
Zotac GeForce 8600 GT ZONE Edition 256MB
HIS Radeon HD 2600 XT IceQ Turbo 256MB GDDR3
Nvidia GeForce 7600 GT 256MB
XFX GeForce 8600 GT 620M XXX 256MB
Nvidia GeForce 7900 GS 256MB
Sapphire Radeon HD 2600 XT 256MB GDDR4
Inno3D GeForce 8600 GTS iChiLL Xstriker3 256MB
Nvidia GeForce 8600 GTS 256MB
BFGTech GeForce 8600 GTS OC2 256MB
ATI Radeon X1650 XT 256MB
ATI Radeon X1950 Pro 256MB
ATI Radeon X1950 XT 256MB
Nvidia GeForce 8600 GTS 320MB
90
90
94
95
98
98
98
99
100
101
101
107
110
141
System Power Consumption (W) - lower is better
Asus EN8600GT 256MB
Nvidia GeForce 8800 GTS 320MB
137
138
139
142
151
151
154
154
155
158
162
166
191
217
Inno3D's GeForce 8600 GTS iChiLL appears to draw slightly less power from the socket than both BFGTech's GeForce 8600 GTS OC2 and a reference design 8600 GTS too. There's a certain amount of variability in how much power two identical pieces of silicon use, even if they're literally adjacent to one another on a wafer - you could use the range from the three GeForce 8600 GTSes as a fairly typical range of power consumption.
